TwinTurbo.NET: Nissan 300ZX forum - Check pins at ECU for damage.
Subject Check pins at ECU for damage.
Posted by Spddracer on June 23, 2009 at 8:51 PM
  This message has been viewed 140 times.
In Reply To Stumped on the Z, no injector pulse. posted by Mikeys300zx(Omaha) on June 23, 2009 at 08:08 PM
Message If you have spark CAS is working as the ECU uses the same signal from the cas for spark and injector pulse.
It almost has to be something from the ECU to the injectors.
Do you have 12 volts at the injectors, key on engine off?
Coming soon!! Zspeedperformance.com
